jerry ACC
My bid at 15cents for the first cleaning, and 10cents quarterly will probably be too high but, I have an opportunity to do this 43,000 SqFt college for a maintenance co. I have not bid yet but going solo I don't think I can go much lower. (18 is usually my minimum). There is also a little over 2000 Sq of tile, but I was just including that in with the carpet. It is Truck Mount HWE only, no EnCrap. The job can lead to many,many more commercial accounts managed by the same company. I have never done a job this big so I have a few questions.
1. Can it be done solo in 5 days with my boxxer 421 ?
2. Should I pimp myself out and bid lower, just to put food on my table ?
3. As a O/O working alone, would you take this job on ? working hours are after 5PM only.
4. Should I try to bring someone else in on the cleaning ?
5. Is it worth bringing someone else in if the guy only pays 6 cents, just for the other probable work ?
Please chime in on your thoughts, especially if you have had this experience.
Jerry
Jerry
