A TRUCK MOUNT MOTOR?
Walt Bush Sez:
This may sound like a stupid question and definately puts me out of the category of DIY - But what exactly makes something an industrial engine? A frame around it?
_________________
Walt
ANSWER TO WALTS QUESTION
non automotive use of an automobile engine.........agricultural sprayers, power generators, carpet cleaner, etc.
gasaxe
bob vawter said:
Walt Bush Sez:
_________________
Walt
industrial use engines usually have a stand alone control system to run the fuel and ignition. As well as provisions for mounting to a frame, if it doesnt already come mounted on a frame.
they usually have a sae style bellhousing or something to allow a stub shaft or engagement clutch to mount on it.
MerCrewser
bob vawter said:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ru=http%3A%2F%2Fshop.ebay.com%3A80%2F%3F_from%3DR40%26_trksid%3Dm38.l1313%26_nkw%3D110328076924%26_sacat%3DSee-All-Categories%26_fvi%3D1&item=110328076924&viewitem=
Lools to have a belted valve train. Not a big fan.......
gasaxe
if its clearance built shouldnt be a big problem. If its not then i wouldnt be a big fan either.
I've heard of a VW engine used in a TM.
Doesn't Suberoo (SP) make a horizontally opposed engine like VW?
AshleyMckendree
Versailles ky
Ashley Mckendree
I wish I would have had an Old VW Diesel Eng to use, instead of my Mercedes... its just too big.
I don't like the pulley I have bolted to the fly-wheel, anyone know where I can get a "Stub shaft" to bolt to the flywheel?
gasaxe
check with a good machine shop they should be able to build one. You may need to incorporate a pillowblock/bearing retainer device as your motor may not like a side load on the rear of the crank.
R W
I always thought that a Honda "Valkarie" 6 cyl bike engine would make a good TM engine. I'd like to find a wrecked one.
