Nov 14, 2013 #1 Mikey P Administrator Joined Oct 6, 2006 Messages 117,185 http://www.youtube.com/watch?v=b0E9iEn0KLQ
Nov 15, 2013 #2 Mikey P Administrator Joined Oct 6, 2006 Messages 117,185 http://www.youtube.com/watch?v=qXM4NyLRQig Reactions: Vincent Feehan
Nov 16, 2013 #3 B boazcan Guest awesome. what did you rinse it with? Is that shower older than you? I had a shower like that once that I stuck a mini turbo on, and it sucked a tile off the wall. Try matching that tile.....
Nov 18, 2013 #4 Mikey P Administrator Joined Oct 6, 2006 Messages 117,185 after scrubbing the soap off, I washed it down with Cobb's Acid and a tan pad and used the shower head to rinse it all down the drain.
Nov 18, 2013 #5 R Royal Man Guest Dry wall sanding screen(with a soap scum remover) is an easy way to remove soap scum from ceramic tile. Give it a try. Last edited by a moderator: Nov 19, 2013
Nov 19, 2013 #6 Mikey P Administrator Joined Oct 6, 2006 Messages 117,185 good idea Dave.... the Grout was the main concern here though..
Dec 4, 2013 #8 Louis Supportive Member Joined Dec 11, 2006 Messages 1,251 Name Louis What do you get for a shower around there? If try to get more than $200 around here they think you are ripping them off. I stopped doing them.
Dec 4, 2013 #9 Mikey P Administrator Joined Oct 6, 2006 Messages 117,185 I won't touch a dirty one for under 300
Dec 7, 2013 #10 Lee Stockwell FOJL Joined Oct 7, 2006 Messages 18,851 Name Lee Stockwell I could hate them less for $300... Reactions: Mikey P
