Blower exhaust hose specs
MerCrewser
Changing belts on my PC 405 revealed a brittle and broken 3" exhaust hose. Any max temp specs for a replacement? I was going to use 3" marine exhaust hose.....
MerCrewser;
As you have noticed, it will fail under the blower heat.
We have 3" OEM quality black exhaust hose in stock. It is rated @ 275° and the most economical.
On our TM's, we use a multi-ply hi-temp hose with formed elbows and 45° elbows (good to 500°).
You also need T-bolt hose clamps.
http://www.cobbcarpet.com/tmacc.html
It is available in straight hose and elbows.
Gene & Jim;
The 4" hose is available.
A few 5" pieces are available. I'll have to check on the 5" elbows.
Larry Cobb said:
Gene & Jim;
let me know I am in need of one....maybe 2
MerCrewser
I have to get it running asap, so I'm going back with marine exhaust. It failed when I tried moving the blower, but it was very brittle. Also, 405s have 3.5", I was wrong about the 3".
