Butler 2 1/2 quick disconnect ?
E
Eric Scofield
Im starting to think R and D at the Butler is going south :idea:
The Butler Corporation is pleased to introduce a newly designed, optional, 2-1/2" quick disconnect to accommodate 2-1/2" hose for the Butler System's "live" Vacuum Hose Reels. Constructed of durable lightweight aluminum, with dual "O" ring seals, a grease fitting and a quick lock release for easy hose removal. Quick disconnect is also available to convert Butler System Vacuum Hose Reels currently in use
sweendogg
David Sweeney
explain why you thinking running a larger hose is a bad idea?
E
Eric Scofield
I run 2 1/2 go too the Butlersystem.com and look at that thing.
Mark Saiger
Mr Happy!
Mark Saiger
I bought my newest Butler with the 2.5 inch hose reel. I carry 100 feet of 2.5 on the reel and break it down in 25 foot sections. Plug off the live reel after I pull off what I want and have a Greenie "Y" splitter set up. I carry into the house 50 foot of 2 inch hose as my lead line. I like the set up. I also use 2.5 inch on my older butler, but no live hose reel set up. You can update to a new 2.5 inch on older models, but you need to replace half of the reel or a least the one leg with the hose hook up.
Mark Saiger
www.saigers.com
Mark Saiger
Mr Happy!
Mark Saiger
Mine has the quick disconnect and it can be a bitch wrestling with the hook up inside the hole of the hose reel. It is easier to disconnect and fight with the hose hook up out of it.
Mark Saiger
www.saigers.com
E
Eric Scofield
The Butler co. will do anything too keep the live vaccume hosereal alive. I wish mine held another 50'
