Castle Guard for vct
Old Coastie
Stephen
I hear good things. My questions are: Have any of you used it and what sort of coverage should I plan for?
This doesn’t sound like a very nautical question.
KSL
Kent
Castleguard is an excellent floor finish if you are burnishing daily. If not Clarion is a better option. Depending how you apply the finish thin or medium coats you should expect 1500-2000 sq ft per gallon.
FB7777
Hey Kent,
where are you in Massachusetts? I’m 20 minutes South of Boston
FB7777
Beautiful country out there, similar to Upstate New York
You’d never know you were in Massachusetts and I mean that in the best possible way
Old Coastie
Stephen
Kent, this is for a post office. The work area (2200 sq feet) is a mess. It will need to be a durable coating and probably will not get much love.
One major issue is that they want two coats, not the seven that Clarion specifies! Another is that my time will be limited and two or three coats may be all I will have time to apply.
"They want..."
Do they want a pony too?
Castle Guard is top-tier...if you follow directions.
Laser is better in a 2-coat restriction.
Old Coastie
Stephen
Yes, that was their specification. I told the postmaster it is stupid. He needs sealer plus three, minimum.
Reactions: Hack Attack
KSL
Kent
I would go with a coat of sealer and two coats of Castleguard. It will have a killer shine Being the post office with extreme high traffic they will destroy and finish without a maintenance plan so you will be fine. You have to be careful applying the 25% solid finish it is tough to apply and if you miss a spot just leave it until the next coat as it does not blend at all. You also need a finish mop and not a regular wet mop.
Reactions: Old Coastie
Hack Attack
Dan
what prespray do your customers normally choose for you?
Not familiar with the products you mention, but if you want 2 coats of anything to look ok and last it better have a high solids %
Hack Attack
Dan
yep never used it, my goto is chemeco armor plate at 35% solids (I think its 35%?) not hard to use like most high % sealers
*32% just checked
Hack Attack
Dan
I'm on a chemo diet. Eat everything I can stomach. Not much for a week after infusions. Then I spend two weeks eating the most fat and protein i can. Cream of weat with whole milk and a donut every morning. Haha. Down to 140lbs so any lbs I can add are good lbs.
stay positive.. its easy to say 👍
my old man is still here 6yrs+ after told he had 6 wks (how long is a piece of string? thats a nautical question 😉) everyone must make their own decisions but "beating cancer with nutrition" is an interesting book which, as I remember it, halfway between both alternative and conventional treatments
Matt Ross
Yeah I'm
Man, I wish you luck. Endure.
Thanks. I caught it fairly early so I should be fine. It hadn't spread much thankfully. I'm in good spirits, and have plenty of support. I will definently be eating better and having a fairly healthy diet after treatment is done. I dont blame it all on our environment, but Its obviously a factor. Just a good reminder for everyone to take care of themselves.
Condog
Tony
I'm sorry to hear you're going through this.
You have a champions heart fighting it.
Here is something I've come across. I hope it helps you.
