Chem Siphon
Bill Soukoreff
I have being playing around with my new simple chemical siphon and noticed a big difference between my high flow wand and my stair tool The difference in total jetting is large and so it affects the chem flow. If I have the flow meter set at 3gph for the wand it will barley register with the stair tool.
The thing is, when I want to use the chem draw, it is for nasties and usually the stairs are the worst. I do not want to be running out to the truck to adjust it all the time. So is the only other option the use a huge flood jet on the stair tool?
FB7777
you could also just go a little heavier on the prespray on the stairs, or carry a bottle sprayer to mist the stairs while cleaning.
To match the flow of a wand, you'd have to have a #10 jet in the stair tool :shock:
Mr.V
build yourself some arms and use your wand :shock:
my greenhorn lite is the bomb on stairs
Bill Soukoreff
I actually do quite a lot, but for some reason curved stairs are all the rage here and there is just no way I can use the wand.
Spurling
its truly amazing how easy steps clean up with some heavy pre-spray and a hand brush ..
