cimex, auto scrubber
sweendogg
David Sweeney
There is a cimex auto scrubber that utilizes the 19 inch planetary head, gravity feet solution tank, vacuum/squeegee/waste tank as well on ebay for $995.00 I'm betting it would work great for several purposes if the squeegee could be left up and the the vac motor turned off when need be.
A couple of ideas: Encapsulation, carpet scrubbing, hard Surface cleaning, Natural stone polishing... talk about faster maintenance.. if you are using monkeys pads or resin discs, would make clean up faster anyways.
http://cgi.ebay.com/Cimex-Eagle-walk-be ... 19c217641b
http://www.cimex-usa.com/pdf/Eagle_Complete.pdf
carpets bog the DC motors to hard....ask me how i know :oops: :oops: :oops: :oops:
yes i tried an autoscrubber on a carpet once upon a time, to pre-scrub
my bad that is the 110v model...still...wonder how its geared...
i have oft wanted one for hard floors...regular autoscrubbers tend to leave a line down the middle where the pads dont make as hard as contact as the center
sweendogg
David Sweeney
Was it a regular autoscrubber or a cimex autoscubber? The cimex to my knowledge is AC based like the standard cimex unit.
it was the regular...
now part of the drag i am sure is because they spin "inward" where as the cimex has that plantery and doesnt "dig in"
i had to adjust the head pressure way light...and even then 10' in i was like "uhhhh damn this aint a good idea" :oops: :oops: :oops: :oops: :oops:
