Could This Work !!!
L
lesterj2
I have had 3 calls this morning asking about grout cleaning...
At the time all I have is a carpet wand AW29..
Could this be used to get the grout looking good...
Or is this the time that I would need a glide...
you don't want to scrub metal wand lips with suction on ceramic tile. get a glide if you want to hack it out with a wand. If not get you a hard surface tool made for it.
You can do a good job with a wand though honestly. Get you a good hard surface cleaner, alkaline, and acid, and a brush. You need to make sure you test spots first to see if you do any damage especially with an alkaline cleaner. I also suggest you do a bit of research before you take the plunge. But seriously your wand can do an adequate job rinsing for the time being....and as you do a few save up for a hard surface tool. Also you should get at least .50 a ft so don't do it too cheap or you wont be able to afford new equipment and all that good stuff.
Walt
3 jobs just might pay for the tools. Get the glide at least. You wont regret that even if you don't do the jobs.
E
esquireservicesinc
Check with your local supplier. They will rent you the right tools.
exactly......rent the right tool to do the job......
