Jul 21, 2009 #3 Zee Supportive Member Joined Nov 2, 2007 Messages 6,193 Name . They can be either lp or kero/diesel.
Jul 21, 2009 #5 Wandslinger Member Joined Oct 7, 2006 Messages 1,006 Name Tom Meyer Re: El Diablo / Greenie or Les Greenie or Les,Any reason the TNT can't use both Kero or LP like the Diablo?
Jul 21, 2009 #6 Shane T Member Joined Nov 7, 2006 Messages 1,663 Name Shane Tiegs I would assume the reason Judson doesn't use a kero burner is that the LP system is very simple with fewer parts and repairs.
Jul 21, 2009 #8 C carpetsweeper Guest I have a powermtic and you do have to be a little careful with the kero you spill it on you and sell worse than a smoker other than that if you keep your system clean and good running order you will have few problems
