ETM Equals #4 Blower TM Performance
When I use a watts to HP converter, I get 1850 watts equals 2.48 bhp. In real life I believe 1.5 HP is the max for 120 vac 15 amp.
https://www.engineeringtoolbox.com/elctrical-motor-full-load-current-d_1499.html was my reference in this case
but even if we use your numbers you are searching for 8+ individual circuits to achieve the same work rate
so unless there is something Larry has that show a serious efficiency disparity or a lack of need for said work.............
Spurlington
Cleaning Professional
Spurlino
Hydramaster beat you to it. That's exactly what they do with the x drive, except it's a 18000 watt generator and instead of vac motors, they power a 4008 blower and pump with an electric drive motor. Why would you even consider playing with vac motors when given that kind of power, you can power a positive displacement blower. The x drive is every bit as hot and powerful as a CDS 4.8.
Using the X drive system to power a high powered porty or 2 will leave an option to use it as a truckmount and offer the option to pull it off for jobs that require the use of a porty. 4 Lx vac motors might be less than $800 .. a 36 blower is around $1500. LX easier to swap out for the little man. No need to carry a TM and a porty. I imagine a 75 gallon waste tank with 4 vacs on top being 12in wide by 36in long by 48in tall. Then a small foot print for a fresh water tank.I have one in my shed that measures 18in x 18in x 40in at 55 gallons.
This set up wouldnt be for everybody but sure sounds interesting. Id even carry an 18in x 18in propane heater along with an electric water heater which would allow me to choose based on my needs/allowances.
Still no mention of hose length?
Let me know when a #4 equivalent that can run on a single 110 is available.
There would be no point in pulling it off to use as a porty because you will be running long power cords back to the truck. Be the same as your vac and pressure hoses. The machine will take too much power to plug into household current. Look, there is no doubt that it's possible but it is just not practical.
Ed Valentine
Ed Valentine
Larry;
In all due respect, why in heavens name would one want to over-load a ETM like that in an effort to beat the competition, or other wise? The poor newbie, as Lee Stockwell suggested, should not be mislead from a professional as yourself. I thought that Nuke Bombs were illegal.
And, oh, thanks go to PigHead for that compliment.
Best to all;
Ed Valentine
Newman
Chris Newman
Then if you're going to use a generator it kind of defeats the purpose of Electro mounts, doesn't it?
It seems to be efficient on a large scale for diesel electric locomotives.
steve_64
I can smell the odor of hot wires already.
Add that to the humidity and how many of these ETMs will catch fire after a few years of abuse.
Spurlington
Spurlino
Yeah alot of overthinking going on .. I was thinking only bringing in half of the set up when necessary. Say for instance .. a 2 corded porty with what ever combo you have (high vac no heat med pressure or lower vac plus heat n higher pressure) without popping circuits. Then when you want to leave it in the truck .. connect all vacs to a Y to create high vac .. use the water otter or which ever then either hot water box or propane burner.
Might be similar to the idea of the Workmaster electric truckmount
What is the added cost of the generator our industry would require. Then aren't you simply just trading dollars?
Acp
Bjorn Marshall
The future is Natural Gas TMs imo. Right now if you already have gas service to your home or business you can get a fill station for around 8-10k
So you would fill belly tank at home @ .48 cents/gallon whenever you needed. You could run a #6 blower machine and a LNG water heater.
If you really went hard you could run the trucks on LNG too.
We used to have a Steam Genie II that ran off propane. It had a 24 hp Onan driving sutorbuilts in series.
Acp
Bjorn Marshall
we run an all propne TNT that Les made custom, its a great machine
we fill the 50gal belly tank for 2.19/gallon but always has me thinking about less than 50cents a gallon for LNG
especially because the truck is diesel so it can also be converted I believe
Reactions: Desk Jockey
steve_64
FIRE BAD!
In about ten years with the bane I torched 3 extension cords and a couple outlets.
As plastic gets hot then cools numerous times it becomes combustible. I watched one combust right in front of me.
I'm loving the PTO.
