Garden Hose Screen
are using a washer hose screen wher yor garden hose connects to the machine.....works great!
Re: HOW MANY OF YOU DUMMIES
Yes bob, any legitmate company that installs TM's puts those on. Mine is just before my fresh water tank. They made sure to tell me if I wasn't getting water that one place to check would be the water inlet as it could clog over time.
Benton KY USA
Re: HOW MANY OF YOU PROFESSIONALS
If you hook to an outside tap, always run it a bit to make sure it's running clean. Over the years I've had everything from wasp nests, a bumblebee, to a small lizard clog the water feed line. Yes we use the washing machine strainer washers on our hoses.
way ahead of you..............been doing it since day one........
Very good jim...but i wuz beginin' to worry about SOME of these nimrods here.....i NEVER have had a clogged jet...and i run 02's....
so i figured i run that bye everyone to rile up Meat an' Greenie....a little!
OHH...and my Stainless jets last me YEARS...running at 650 pressure!
you ain't rilein' me up Ole Man.
I have one of those wasing machine strainers on the inlet.
I also have a bowl strainer mounted upstream of the pump on the TM.
all TMs do, right?
you put a bowl strainer on your "new" SG's don ya???
http://www.grainger.com/Grainger/items/1GYD7
Max. Fluid Temp. (F) 125
Material of Construction Nylon
Max. Pressure (PSI) 150 @ 70 F and 100 @ 125 F
Sorry Larr.....even my Stean Genie gets over 125 degrees and most certainly puts out way more tha 150 lbs.....
Yous jus GOTTA git rid of that Harbor Fright mentality...
step up...think billit SS!!
Years on an 02 ain't an 02 any more pops. The good news is at least you ain't misting carpet as bad as we had thought....but...you better turn the pressure up each year cause you ain't hitting the rug with that knife like strike of a sharp new jet, you are just garden hosing it.
I'm also waiting for a gem yet to come from Bawb...somehting better than butcher paper and hack juice. :roll:
harryhides
Canada
Tony
Listen old man if you were using DI or RO you'd be way beyond this amateur move.
"butcher paper and hack juice"...
Already makes me two up on most all yous here!
You know Bob, I really like you're attitude and can see why people like you. And also I have come to realise you aren't going to change a thing. And you might as well not because then you just wouldn't be Bob. You do really remind me of a Tile installer we used to have in my in-laws carpet biz. He was a good guy, too bad he had to retire early due to congestive heart failure.
Harry...you DO realize whom you are speakin' too.....right?
there he goes...that's Mr Bob......The Ghetto God!
i clean their Rat Nastys AND call 'em dear!
I been doin' this shit FORTY years....come on?
umm, Bob, I don't think city water pressure or temps are an issue thru the strainer.
it goes BEFORE the pump...
you knew that, right??????
and you run hot water thru your pump?
how come??
and i guess you're saying you use no pump strainer other than that crappy washer screen that small tadpoles will slide thru????
:roll: :roll: :roll:
sorry Meat i read yor post wrong...NO...i don have one of them dohickeys on my machine...but we use Detroit City water so we don have much problem...
I've been gone for a bit, only able to view the boards for a minute, or two, each day. I get on this morning with a bit of time to cruise the site and the first thread I click on is this DAT.
Everything is normal.
Scott
Bob you know as well as I that the Detroit City water system barely filters out large needles.
Scott
I was reading that Auburn Hills, draws from Lake Huron.....that's pre-needle water!
tell us about brOOm strAw.....
