General Pump rated @ 3.5 GPM
Johnnyone
I have a Pro chem 4 jet wand with 95015 jet. This would be rated at 6 GPM. Everything seems to be running OK so far. I usually run about 500 psi to 800 psi.
Would the High Flow demand damage the pump?
Am thinking about going to more flow also
Thanks for your posts
Stick your wand in a bucket for 60 seconds....it'll be a fraction of that "6 gpm" number.
After that, you'll be swapping those 015 jets for 03s thinking you aren't putting down enough water.
i checked my 4 03s at 700 psi ATM...was 1.25 gallons...
you have to remember that is the MAX that pump will do...I was hoping for a combo of high pressure and high GPM, but while talking to a pump guy, he told me you rarely get the 2 together..also depends on whats running it and how much HP you have to spare for it
Four 015 jets may total "6" but that is not the same as 6 GPM. Gallon per minute flow depends upon the pressure, length of hose and other plumbing concerns.
You will not be putting out anywhere near 6 GPM if you are operating in the 400 to 500 PSI range.
No worry about the pump keeping up. Just make sure your vacuum set-up is worthy of the flow rate.
Scott Warrington
