gum removing wand
Bucey
Anyone ever used one? did it work? Also what solv do you like to use on old gum in commerical carpet? and I mean old gum black and trampled.
Bruce
Never used a Gum Removing Wand , but I use Judson 02 straight , works just as good as any solvent.
juniorc82
I use some aresol spray and freeze it then chip it out with a old flathead screwdriver
KevinD
Kevin Dumas
Quickest way I have found for the really hardened flat black ones is to take your favorite solvent, POG, or gel solve and apply it to the spot and then poke it full of holes. I like to use the Crane seam roller. They cost about 20 bucks but if you don't have one you can even use a fork to poke a bunch of holes in it.
Do this before before you even set up the cleaning equipment. By time you get to them during cleaning they will be soft and pliable and come out much easier.
