Have any of you cleaned your roof recently?
Weebco
Houston Texas
Gary Wiebe
I am trying to get the mold of my roof after about 14 years of installation.
I have used bleach, I have used magic wands "grease eater" with the hydroforce and t.m. Still looks black, was light brown when new.
Gets a little lighter each time, but still looks bad.
Whats is your suggestion. Have any of you cleaned your roof recently?
I have no experience with them, but have you tried any products sold for removing mold/stais from roofs??
also, do over hanging trees block sun light from that section of roof?
if so, it will be a recurring issue.
i did a quick google search on "roof mold removal" and found some info.
Maybe you'll find it useful
Mark
I cleaned my roof this summer its a brown roof (was then black in areas) aprox 17 years old. I pre sprayed it with purple power from advance auto (out of a pump sprayer) let dwell and agitated with a push broom then just pressure washed from the top down very slowly and it came out great.
Shelbyville TN
A friend who has a roof cleaning business uses a diluted bleach solution (1 to 10) with detergent and surfactant added. Low pressure spray application. Dwell time. Rinse.
Be sure to protect plants from effects of bleach.
Scott Warrington
Idiotâ„¢
There is a product named JOMAX that you can purchase from paint and hardware stores that you mix with bleach that works very well.
Utah
damn glad I live in a DRY state...
mold on roofs and drive ways...WTF :shock:
Rex Tyus
Bleach and a high alkaline prespray. Pressure wash between 1200 to 2000 psi depending on tolerance of roof. TECHNIQUE IS CRITICAL. Easy to damage. Simply spraying on and rinsing off rarely provides good results. Good luck, be careful. I almost died on a metal roof once. A safety line would be a good idea. Roof pitch can be deceiving from the ground.
Clean, WTF, Winds two weeks ago started to take it off, got it patched for now, gotta replace this summer..... Gonna spray the moss off and put another layer on..
Becker
Snohomish, WA
Becker
In more ways than one!
Utah
hahaha funny
NOT!!!!!
I dont drink so i dont care...
whats funny is there are southern states that have counties that are a lot drier then we are
