- Oct 6, 2006
Over a decade of Prochem Titanium use had me spoiled..
I never needed to heat up a Glide to get it on or off.
Installing anew Hole glide on the Dev 12 without it was impossible.
3 minutes with a heat gun on high moving quickly back and forth did the trick.
My concern is removing it without damaging the holes.
Btw, a chisel works better than any flat head for removing a Slot... Grind down the edge of you want to get geeky about it.
