Help, floor buffer doesn't turn off
alazo1
Anyone had this happen?.
It started yesterday halfway through grinding of a travertine floor. On and off now is only through plugging and unplugging. not good.
I though I've heard that there is a pin somewhere in the housing that needs to be reset.
I don't remember the make of the buffer but it has a dual capacitor motor as others do..if that helps.
Any ideas?
thanks,
Albert
Brian R
Brian Robison
Video??
I've busted a few door jams in my day from faulty switches....Good times. :roll:
Brian R
Brian Robison
Lol. You think?
It can be fixed but I'm the guy who always took it to the shop.
John LaBarbera
Do your switch levers function properly? On a Hawk machine the switches are normally on. They have a spring that pressures them into the off position and when the levers are squeezed the swith goes to it's normal on. In other words the spring under the switch cover may be broken or displaced. Just take the cover off and look.
alazo1
I riged it today with a extension cord and electric outlet and noticed it was actually working. Don't know, maybe it just got hot and stuck.
Albert
you should go ahead and order and replace that switcc for safety reasons.
