How we clean tile countertop bullnose
GCCLee
Way to go guys! Thanks for the lesson ....
Hope the Boss bought you a beer : )
Sent from da parking garage of dee detention center
bildung
Dry Vapor Steamer with a brass tip for the whole counter top and the bullnose; 3-4% water, no need to cover lower cabinets; done in minutes.
Especially efficient alternative if the counters are all the HWE hoses are being pulled for.
not exactly, it's been re-jeted to my specs for better coverage, a higher psi trigger and a ten foot hide a hose is included.
Reactions: hogjowl
GCCLee
What PSI was he runnin on ?
I ain't been over 700 yet and 1k is Max Top so...
I've had 800 psi in mine with no problem. How much do you use on yours?
Re- jetted for "better coverage'? Are you serious?
Rejetted so it doesn't spray out the side, rookie.
It's a 1200 psi valve, I think.
rwcarpet
Robert Hodge
Is Cali the only State that has such an abundance of ceramic tile counter tops? I've seen them in SoCal also....many of them. The only ones I see in my area are from 75 year old houses that have never been remodeled.
Reactions: hogjowl
