I got a new truck today
for the price of a lid .a mallet and some advice.......
it is a whole new machine .... I fired it up tapped on it some turned it off and spun the lid
fired it up tapped the lid.....and it pop ed down and my lift went higher then it has ever gone before
the whole machine sounds different and .most of all hardly no water in the lines........... It use to drown my leg when I would disconnect from the RX and now it barley drips...................
I called A/T and told them not to send another lid..I am going to leave good enough alone and just add the mallet to the tool box...............
Thanks for every ones help.........
adamh
Nampa Idaho
Adam Hale
That dang things been leaking the whole time? That sucks What is your lift set at? I set mine at 18.5 ish
lmao
I knew it!
Do like I do Jim, put your ass/hip against the driver's side wall and pretend like you're gonna give the lidded tank a sniff of your arm pit and shove that baby down tight.
My god, I bet you gained 20º right away.
I bet thats why the seal was all screwed up... All that air blasting it away...
You goof!
Goof ??......................how was I to know............
I could here the air .I could here the spring..I could here the ringing in my ears...........best to my knowledge this was normal because this is the way it has always sounded........
I have never messed with the tank..to my knowledge is wasn't giving me a problem...........every few days I would take off the lid and clean it and hose out the tank and keep going.......Until the gasket fell out....
I was always questioning the lift but it was not a real problem because I am still getting great dry times .........
Greenie set me up not to long after I got my truck........
the only way to go..
No kidding...
Set the loner up with 018 like Wolfman.
And for christ's sakes get a damn Vanifold.
No wonder you never got any walk ups, you've been soaking people's carpets left and right...
LMAO!!!
You got a reputation around town as the big truck pad soaker.
lol j/k Jim..
lol......... another perk of living in the dry desert...........
no matter how they run............ unless you walk in with a rug doctor
you still get damn good dry times............
Funny thing is I was always getting great dry times.........
so even screwed up it was doing good.............
Priceless!!!!
How much did that cleaning rig cost? and you have to put the lid on with a hammer since new? Naw no thank you.
