lip in van to keep water out of front passenger area
JoeClean
What is the best caulk, goop, or sealant, to use?
I'm gonna pick up a length of angle iron to run across the van where the front mat starts.
Run a thick bead of ? and then screw the angle iron down.
Recommendations? Or a better way to do this?
Just had to pull the front mat and insulation from a tank overflow. Ugggh.
Thanks
something flexible like window silicone.
I used the black stuff they install windshields with.
dgardner
Instead of angle iron (steel), that you have to paint to avoid rusting, perhaps use angle aluminum. Only a little more expensive.
Johnny
Johnny
I just pulled the soggy mat out of mine. Going to extend the liner all the way to the firewall.
just go and get yourself some 1/2 inch or 3/4 inch aluminum angle iron.....drill some small pilot holes in it....take some liquid butyl rubber sealant and coat the bottom of the angle iron...put in place and use some self tapping screws and put it in place....then take more butyl and caulk it in...butyl is the best water sealer out there for this type of application.....
JoeClean
For Jim
Does the butyl rubber dry or is it always tacky.
Will it get all over any wires or hoses that happen to rub against it anytime in the future.
Thanks
Re: For Jim
Thanks
A high quality, tough, butyl rubber sealant, ideal for jobs requiring a durable watertight seal.
Key Features
Interior/Exterior Use
Available in White, Black, Bronze & Aluminum Gray
Paintable
Remains Flexible
Mildew Resistant
1. Excellent sealant for use around window & door frames, in expansion joints, around concrete
foundations & on gutters & end caps.
2. Excellent sealant for sealing joints in sheet metal.
3. Filling and caulking joints in heating and air conditioning ducts.
4. Seals gutters and downspouts.
