Little Giant Users
Louis
Louis
So how many of you have the 600 psi little giant and how do you like it?
How do you do tile cleaning with with 600psi?
I have a old #2 that I might use but I'm not sure I can deal with less than 600 psi. for tile cleaning. A spinner takes at least 500 to run.
Thank You
Louis
Louis
So no one is running a little giant with 600 psi
Louis , is 600 psi the max psi the coils are rated??
and personally, I don't think anyone needs more the 500 psi to clean carpets .
Don't anything about stone work though
Louis
Louis
Yes thats what the low pressure coil is rated for. It will be fine for carpet but I sometimes get big tile jobs that I use the spinner on.
gotcha
since you already have one, and want to utilize it....
maybe a quick disconnect set up, or some other by-pass hard plumbing like on home water softeners .
of coarse you couldn't use it for tile , but could boost your heat for carpet and by-pass it for T&G
rhino1
We had one that held way past 600 psi but it wouldnt stay hot while cleaning tile.
Louis
Louis
The bypass may be a good idea. It would just be untill I got the money for the high pressure little giant.
Maybe a gekco wand at 500psi would do the job on tile until I could get the hp unit
