alazo1
I just did some test on a few I got today from Cobb. Only got the 400 and 1500 grit. I wanted to try a 2 step process.
Ran the 400's and did cut the marble. Went straight to 1500 and it was pretty sad. Went back and cut it with 400 again then this time I put polish powder in the 1500 and got an ok shine out of it. Problem is the clarity sucked. You can't compare the abrasive they put in these vs diamond pads.
The other side of the test area I ran 400 grit diamonds and powder polish. Much better results.
Part of my garage floor before.
Slurry from Cobb pad at 400 grit
Slurry from diamond
Diamond abrasives. Machine is a regular buffer with 50lb weighted driver
After Left is Cobb pad, right is 400 grit diamond and powder polish
Albert
Slurry from diamond
Albert
