Mytee 1003dx 5 years old bypassing
tubguy
Good evening
I have a Mytee 1003 dx appx 5 years old. Then machine had been working fine. Builds good pressure. Heat was a little cool so my Distributor advised de-scaling machine. After running machine de-scaling, I noticed that the water in the fresh water tank was being routed to waste tank via by pass hose in waste tank. I see that that hose from the waste tank is attached on the other end to the pressure regulator. I took the pressure regulator apart and lubed up the pin with silicone spray. But it is still pumping water from the fresh water tank directly into the waste tank. Any ideas on what needs to be repaired. I was hoping to clean rental tomorrow.
