orek low boy OP
Not enough weight to OP (grind in the dirt) but it makes a good little pre scrubber for real cleaning ala' HWE
Jeff Madsen
I owned one years back - it was a POS. The handle release mechanism will break on you, excessive vibration, screws holding the brushcup on to the main shaft shear off, excessive heat build up, etc. etc. My advice is to stay away..
