Photos of MIKEY'S AND WARREN WALLACE'S LUNCHPAIL.
Mikey P said:
Over kill for a back up or what?
150 gal. SS Waste Tank 127 gal. usable
30 HP Kohler Engine
Sutorbuilt 408 Tri-Rotor Blower
General Emperor Pump & Clutch
2-2&1/2 in Vac Inlets
2 in. Bayco Relief Valve
SS Blower Fittings
2 Hi Flow Mufflers
#4 Little Giant 180,000 BTU Heater with mounting brackets
Adjustable Pump Bracket
THIS IS WARREN'S UNIT
That's an awesome looking machine.
I wonder why he didn't go with a 59 blower and slightly larger motor.
Will it be able to dual wand?
Becker said:
work of art!
I'm not going at ask what Mikey paid, but what does that same machine retail for?
This unit will maintain 240 degrees on a Greenie 10 flow wand or it will maintain 240 degrees on two standard flow wands. This unit is fully capapble of running two wands if needed.
It has the legendary TNT layout design, uses the most common local available parts. All the components are easily accessable. Once the unit is mounted in the side door of a van the pressure pump is located between the driver and passenger seat. Also the blower and engine maintenance can be performed from this position.
The price of this unit is $16,995 and includes the base unit, #4 high pressure Little Giant Heater, 100 feet of vacuum hose and pressure hose and one 12 inch standard flow wand.
You are looking at my 2nd west coast demo machine, The TNT-500 I think it looks sweet, kind of an urban commando S.W.A.T. thing going on.
I think I see another TNT in the background headed this way as well, what I now call the Classic TNT.
How about some tnt Dynomite graphics waterjetted into a polished sheet of stainless, done on a Radius bowing Out, Judson across the top, dynomite in the center, TNT-500 across the bottom, would look clean.
N GA
BradFenstermaker
Nice very Nice. Congrats Mikey and nice job Judson. I love the simplicity of the machine.
You may be running the van more than you thought.
Later
I have a 20 year old TNT I bought used and Les rebuilt it 4 years ago and it runs like brand new every day and night
Lansing Mi.
Kevin McCreary
30 hp, air cooled, #4 blower, propane heat, huge foot print?
Is this a 1985 special?
Sounds like a step backwards to me.
Propane? With all the free heat from the engine and blower?
At least they put a Kholer moter on that bad boy you will be
able to swap that thing out quickly and cheaply after few thousand hours.
4.8 GardnerD dual splash, rocking INSTANT UNINTERRUPTED heat. The 70's had the best music and most thing only got worse.
Go measure your pos Titan and waste tank's total foot prints and compare it to the Pail's.
It will be twice the size.
when vEEgs dumps his POS Vortex next year and buys two Lunchpails to put in a box truck, will the Mikey wannbes dump their POS V's to "be like Mike"?.... :lol: :lol: :lol: :lol:
You heard it here first
watch it happen
Marty's POS V will be the first to go
they wont be buying Problematics thats for damn sure.
and why wouldn't they want to be like Mike, I'm the most wonderful person in the world.
just ask Lisa.
if it were choked down by Hydomyster I would have to agree.
With the 2.5 filter less Judson set up it will equal your 59 in performance in every way.
Lansing Mi.
Kevin McCreary
Doubt it. The way the Titan is set up it will blow your 6008 out of the water.
Its as good if not better than my old 7008.
