Removing red silicone from berber
So we have Been requested to try to remove a few drips of silicone. The HVAC company called us in a panic, and this is one I’m not so sure about. They wiped it up, so they smeared it...
Any suggestions?
Shane T
Shane Tiegs
I assume it's already cured? There is probably something better but seems to me that WD40 has loosened silicone when used in the shop on auto repair. Just a guess on my part.
Reactions: Sierra Clean Care
I had a similar call on that stuff, only it was beige color. It might be different than red silicone, but I had no luck.
My plan was to try 99% iso, nail polish remover (acetone), or OilFlo....
Short of those 3 things, recommend replacing...
Reactions: Papa John
Prosoco is just down the road a bit. Lawrence KS.
Not sure if they sell it this cheap but its listed they do.
Well, no dice...
The contractor tried to clean it up, and mashed into the carpet so deep, he frized the spots....
I tried goof off, nope...
Well, no dice...
Let the contractor deal with it. You'll only delaminate the carpet at this point.
