Rotary Tile Brush
P
PTMatt
Does using a tile brush attachment on either a 175 or the 360i save you from having to manually scrub grout lines? Have a big tile job tomorrow and was wondering if one of these attachments might save me some time.
Matt;
Assuming you prespray, have a TM with good heat and flow . . .
yes, the 360i hard-surface head will do a good job of cleaning the grout lines.
The brush has abrasive impregnated into the nylon for added agitation.
The 3M segmented brushes with abrasive are fairly good on a 175 machine,
but lack the hard-hitting washjets.
GeneMiller
gene miller
i used to scrub everything years ago but i don't find it necessary. i had the original steamway tile tool with tiny jets but once i installed 04's i didn't need to scrub anymore. i think it originally came with 01's or smaller. i have the turbo now and it blasts just fine at 1100 psi. i still scrub the edges under cabinets.
gene
P
PTMatt
gene
I've tried not scrubbing on a few jobs before but it just seemed like I wasnt getting the same results. I currently use the SX-12 with my Butler.
My local supplier sold me the Tampico brush for my 175. Anybody use this? Seems like the brissles are kinda soft for tile.
alazo1
The best brush I've found was John's op brush on the conqueror.
Albert
Johnny
Johnny
Albert
I use that brush on a Brute. Works better if you strap a little weight on it.
I still use a pole brush on every job.
Brian R
Brian Robison
Is it that pet clinic?
GeneMiller
gene miller
if you need to scrub every job to get the results then i would suggest a change in your chems. i pretreat a large area and then start. occasionally i have to retreat a bad area but it's rare. i use powerbreak from bridgepoint with oxygen bleach as a boost .
gene
P
PTMatt
gene
I tried not scrubbing today and it came out Great! Just boosted my chems a little. Man it saved me alot of time!
Gonna try the Powerbreak with oxygen bleach as boost. Thanks Gene
