Rug tagging system.
Redding
@Brian H , @T Monahan , @Ron K
The rugs are starting to pile up a bit and keeping track of everything is becoming a job in Itself. I’m still small and looking for a good way of tracking my rug flow. I'm not at the point where I can't afford a $400 a month tracking system. Looking for some sort of water proof tagging method. What do you guys suggest?
I currently have 28 rugs in my shop in little piles so I don't get them mixed up. I can see this is going to be an issue if I don’t address it.
Ron K
Tyvek tags and a Takit gun work for us. Take a quick photo upon pick up is a good back-up too. Even all piled up you can usually figure out who's who's if you keep each customer separate piles.
roro
Wellington
Ross Craig
The rugs are atarting to pile up a bit and keeping track of everything is becoming a job in Itself. I’m still small and looking for a good way of tracking my rug flow. Im not at the point where I can afford a $400 a month system. Looking for some sort of water proof tagging method. What do you guys suggest?
I currently have 28 rugs in my shop in little piles so I font get them mixed up. I can see this is going to be an issue if I don’t address it.
Tie them on with string or wire. We also use them for blinds when doing a commercial so we can make sure they go back to the appropriate window. Saves a lot of time especially as blinds can have slightly differing widths.
roro
Redding
I fixed the typos in my OP. Wow, I should not post while sitting in my shop covered in rug dust on 108° days.
seattle
You can get the Tyvek tags prewired. I'd recommend against using the dark colors as ink doesn't show up well.
Oh yeah, use permanent ink.
Reactions: Shorty
