Service Advisory for all TM
GeneMiller
gene miller
I replaced my vacuum gauge today because it was looking a little yellow and worn out. Boy was I surprised when I hooked it up and it read 20hg. I went back inside to get another one just to be sure and it read the same thing. The old one was reading 15hg. Might be something worth testing.
gene
L
Leslie Judson Jones
gene
CK and see if the vent cap or rubber tip is cut open on the top of the gauge.
KevinD
Kevin Dumas
[/quote]CK and see if the vent cap or rubber tip is cut open on the top of the gauge.[/quote]
Well don't just leave it at that.
Is it suppose to be and why?
L
Leslie Judson Jones
Is it suppose to be and why?[/quote]
Sorry , after you install the gauge you cut the rubber tip off so it will vent.
LES
LES
Maybe that's why my gauge reads 15"-17". Cut it completely off or poke a hole to let it vent a little?
GeneMiller
gene miller
I had the original from the factory and the top was not cut that I could tell but the new one has a little metal piece you pull up.
gene
