Shootout results
Brian L
Hollister
Brian L
It's a looooong train ride to BC.
I hope Ron spells out the criteria and specs like we're 5 yr. olds, cause I know some dimwit will pick his results apart, you had to be there, it was all very serious, everyone wanted a fair shootout, many eyes were watching, some pics would be good too, I know if you give Ron enough time he'll put together a nice presentation on the whole ordeal.
specs schmecs
there's only one spec I'm interested in..
which porty recovered the most water
Was it that complicated or mysterious that you can't say?
Mike mentioned the one with the most CFM had you brainiacs scratching your hEdz trying to come up with reasons why it recovered the least water.
you know anything about that?
Mikey P said:
All 5 machines recovered the one gallon they put out.
with all being pulled with same wand stroke, same psi?
GTF out.....
I mentioned in another post I didn't expect to see much difference in any of the porty's recovery.
But figured there would be SOME difference other than "subjective" comments/thoughts of those that were there.
(that are sure follow after Ron posts the findings)
Utah
i want the fookin video of the in-house cleaning poor bastard....
Hawaii
No Sh!t.....
Mikey P said:
Valentine was leaning so hard on that wand the water didn't have a choice.
Valentine was a BIG help in the portable shootout! Good job Eric, Ron and whoever else helped!
Specs schmecks.....I know the first time someone sees a 100 cfm machine post 114cfm on the chart, the results will be schewed. I "heard" that they used an UN-glided wand on the recovery test, I can't wait to see what a high water lift unit will look like on paper when the naked wand was glued to the floor, should have used a hole glide for all units to give them a chance to show their strengths and weaknesses....but hey it's a starting point, I expect to see Shootout II in the future.
I would like to see an Operator comments section of the report, be interesting to get user interface coments as each unit is being demoed for testing.
since nearly all "out side" the boards don't use a glide, a glidless test would be of practical use
and since 3/4s or better of the CCers out there don't vac, a hole glide is little use to them
come on, Ron
Just post what you guys found.
If it's inconclusive, so be it .
Just put it out there
..l.T.A.
