Show your sprayer modified or upgraded
K
Ken692
I know there are some great pretreat and spot sprayers, the hydro and power-force come to mind,
On a job today my little $40 spray bottle quit, I could not help but think I can put together somthing better, you know like a tire pump or battery ??
Have you modified yours did you make somthing great?
clean image
Carl Maddock
18 volt driving a 12 volt pump?
Northern sells a 4 gallon that takes a BD battery and also green something that also takes a lithium battery
Both under $200
I returned both of them after testing
K
Ken692
Even if it's 110v or 12v
Anything is better than pumping them by hand
K
Ken692
What's a good pressure in a pump sprayer ? 10 or 15 psi
I have a few older car tire pumps, it's just easy to hit a few pumps and your on your way. It's funny when the tank is full of solution it's only two pumps but when it's running low you need a ton more air, and quite a few more pumps.
