staying connected....Lay Flat
Beeks
Orlando
J.R.
when connecting lay flat to air movers and dehumidifiers what do you use? Im guessing some kind of tape? What kind works the best? What are the other options?
A planet far far away
Like Keith hose clamp for dehumidifiers. Bungee for airmovers, just pull it tight enough. If needed you can also use zip ties connected together but then you can only use them once.
Reactions: Beeks
Beeks
Orlando
J.R.
ok sweet! Yea heard multiple good ideas for on the dehus, but not air movers, bungees sound like a great one!
Works well just pull enough up and over the bungee so it doesn't creep on you and you should be fine.
We also use turbo ducting for airmovers and sto & go for axials. Lay flat is much cheaper to buy and use but the ducting lasts forever. If you find you use it a lot, you might consider the ducting.
http://www.drieaz.com/_DEC/DEC_Product_Base.aspx?decID=1032
Reactions: tmdry and Beeks
