Tile cleaning procedures.
Bucey
I going to clean some tile in my house with the hard surface wand. Is hot water just fine and what about resealing the tile grout? Never done this before and could use some info.
Carpet Cleaning Fool
Re: Tile cleaning pro
The floor will turn out better if you apply a tile and grout cleaning solution prior to using a hard surface tool.
Some products even require dwell time for the chemicals to be most effective.
Hot is good. The hotter the better.
Bucey
Is 240 hot enough and 900psi? Is there any need to treat the grout after cleaning?
I opened up the Tile and Grout room for you.
Don't forget to get some sleep tonight.
