TM Flood Pumper
Devin Munroe
I saw a TM Flood Pumper in either ICS or Cleanfax. Does anyone know who the manufacture is and how well they perform?
Devin
Blueline has the Super Extraction System, was it this one?
Kohler Engine 25 HP
This gasoline-driven, 4-cycle engine features an overhead valve design engine which delivers peak power and performance. It is also easy to maintain.
Gardner Denver Ti408 Pump 405 CFM
This pump has a proven track record and provides optimum vacuum performance.
Waste Recovery Tank 120 Gallon
Marine aluminum construction with automatic shut off at 120 gallons.
Optional Auto Pumpout
Allows 6.3 GPM waste disposal, significantly higher than competitive waste pumpouts.
Large 3 Inch Waste Dump Port
For quick dumping and easy clean out. Dual Vacuum Ports Allows dual wands for faster cleanup.
Compact Size
The unit measures 38â€ÂÂ
