- Feb 4, 2016
- Name
- Matt w.
Rumor has it that Legend is gonna do away with the vacuum brake assembly and have the relief valve directly on the waste tank.
So Is it gonna be a kunkle valve or will it be cheap like Hydramaster's lazy valve on their thin flimsy recovery tank? Does that mean the max HG requirement is gonna drop from 13 to 12 also?
First goes the removal of the external water box combined with the exhaust heat exchanger
Then they remove the Helicoil and replace with the plated heat exchanger
Now the Vacuum brake assembly on top of the blower?
And the cost still increases on these machines.
