Water hose
cape coral fl.
jack zerkie
What do you use 3/4 or 1/2 inch hose water supply Iv'e used them all but they get heavy . No don't use a reel. How does air hose for pressure and volume or is their something better. Thank you jz.
Absher Carpet
Delaware
Jonathan Absher
I have been using this hose for about 6 months or more. I had a different brand that was thinner it ended up busting.
Absher Carpet
Delaware
Jonathan Absher
I also have a 50 ft Goodyear hose that is coiled up hanging on inside of van door with a quick connect on the end so I can hook into the flexible hose easily.
tried a bunch over the years including 3/8" air line
always went back to the red rubber 5/8" hot water rated stuff .
(Never seen it in 1/2" or I'd of used it instead of 5/8)
.L.T.A.
Onfire_02_01
Minnesota
Jeremy Gray
My last machine used an air hose on a live reel as a water line. I never had any problems with it. I wish I could go back to it but with my new machine I don't have any place to mount it.
Absher Carpet
Delaware
Jonathan Absher
90% of the time the Goodyear hose stays coiled up, I just run the zero g hose to water source and connect to Goodyear to either fill up tank or waterbox. With keeping 100 ft of water hose on van I hardly ever fill up fresh tank.
