frank fratto
- Jan 27, 2018
- Name
- frank fratto
You be careful with that 300-- lolIf you got to work, you might as well have FUN and be Profitable!!!
Same, I look forward to using it every chance I getJust like riding a bike.
OP's are great!
I just happen to be a 175 Man LOL
It's the small things in life!!!!!!!!My grandsons did about 4k ft of carpet today. I'm winning!!! I wasn't even there to take some pics![]()
WOW!!!The first time using my 175-300 putting down solution from my tank was a total success
I just used 175 never used the 300
I used 14'' Red Pad on 14'' Driver to scrub and extracted with 17'' Ironman Bonnets. I used both sides of the bonnets
10'' CRB to groom
I used 5 oz of Carpet Details No Peroxide
I love VLM !!!
View attachment 133509View attachment 133510
View attachment 133511View attachment 133512
Carpet details is not a true encap as far as I know. Has no polymers. You should try Saiger's code red of encap. It's a liquid, easy to use, has a good amount of peroxide already, acidic in nature which makes it great for fine fabrics as well.One job today for long time customer with old nylon. I go to this house 2 times a year
I'm using Carpet Details with 5 oz of peroxide
You say no heat
A few years ago when it was my main cleaner I thought I got better results using Carpet Details with hot water
It's cold 25 degrees and I take my own soft water. So that water is cold when I get to customers house
I put a bucket heater in jug when I get there so water is at least warm 80-100 degrees when I start cleaning
Is that ok ???
I was going to use Releasit or VacAway but I thought I might put down too much solution which would make the carpet stiff
If you have a 175, tank is a must!!! and shower feedI was going to use Releasit or VacAway but I thought I might put down too much solution which would make the carpet stiff
Turns out I used less with the tank than I usually do spraying it with my WORX
Still never tried Saiger's
Carpet Details dries to a powder
www.carpetdetails.com
love my Ironmans, I have small ones I use under a Stepson as well.The first time using my 175-300 putting down solution from my tank was a total success
10'' CRB to groom
I love VLM !!!
I used a Red Fiber Pad this time and it did a outstanding jobWOW!!!
Look at those pads!!!
But where does the dirt go????????? LOL
I use a Stepson on steps toolove my Ironmans, I have small ones I use under a Stepson as well.
I am mainly HWE but I like Scots , usually when doing commercial type , I have some of Bonnet Pro stuff,I use a Stepson on steps too
What encaps do you use
Carpets look great.The first time using my 175-300 putting down solution from my tank was a total success
10'' CRB to groom
I love VLM !!!
10'' CRB to groom
I love VLM !!!
George,
Yea another HWE Guy that's ANGRYGeorge,
We have, been doing it all wrong?
We need to flood the carpet!
Soak it really well!
And then put 10 or 12 DRY STROKES on it?
I think I finally GET IT!!!!!
I see the Light!!!!!!!!!!!!!
FWIW, and I resize, not much.
Yes on hard surfaces.Tony ,I never used the square scrubber.
Do you like it?
I guess if you can get two together, you can make a choirGeorge,
75 k ViewsI guess if you can get two together, you can make a choir![]()
Some people on this thread can only afford to have one horse?I'm just speaking the truth! Vlm has its place, and obviously I use it, a LOT! It can not be a one trick pony! By the way, a square scrub tool is the cats ass, although I don't use the Square Scrub brand because of weight for removing finish off of vct with spp pads. Merry Christmas![]()
