256:1
Bill Soukoreff
Some chems say to mix in 5 gallons and meter at 256:1. How do you convert that to GPH?
Would actually depend upon your flow rate and other factors. Should be close to 4 GPH.
Richard's math is exactly correct. It is just his logic that is off.
Clarification
The original question did not state how much concentrated cleaner was added to the 5 gallons. I assumed adding 1 qt of concentrate to 5 gallons of water. Metered at 4:1 this is close to 256:1.
! qt per 5 gallons is the dilution our rinse and emulsifier products use. Several other major manufacturers also use the same dilution.
H
harryhides
You are all wrong and Marty is simply trying to look like he has a clue.
Bill is from Canada where we use real ( Imperial ) gallons vs the weeny US gallon.
One Imperial gallon = 1.2009499 US gallons.
Of course if you are using US product then Scott is correct - just his logic is off.
:mrgreen:
Newman
Chris Newman
So the volume of a liquid increases as we travel far too North? :wink:
I wonder how much volume a gallon equals in Alabama?
gallons get smaller the closer you get to the equator
They are back to a real gallon again by the time you get to Australia
Must be the same reason your guys health care is alot better? :twisted:
Just razzing the guys up top.... :lol:
