after market electric reel
John Watson
Mine was made for the previous owner for $1,200.00. When I bought his shaft drive unit (A basket case In boxes and pieces taken out of the truck, Now in it's 4th truck.) I gave him $600.00 for all... Mine is controlled by a pressure switch which is long enough to reach the ground in front of the unit so I can step on it and keep my hands free. Sort of copied after the Bane clene reel.
Greg;
This is the chain drive model that we've used:
You can add one or two solution reels to the left side.
Mikey Board Supporting Member
Greg Loe
I was wondering if there is something to add to my current reel
sprocket,... 12 volt d/c motor.... a relay and your choice of a belt or a chain and
a handful of common since and you can add to and build it yourself.........
There was an add in cleanfax and ics a few years ago, in the classified section. you could by a kit to fit the hose reel. I think he also made either a hose washer or the things that lifted the hoses of the ground. If memory serves he is a carpet cleaner that lives in Grand Forks ND.
Sorry that is the best I can recall. Look at some old mags . around 2001-2004.
