- Oct 25, 2016
- Name
- Swani
Is there a specific way? Or do you just eye them up?
I guess I'll have to get a friend.eye them straight
unless you're cockeyed ..
then have a friend eye them straight
It's a PMF Mach 15 6 jet and although it seems dumb aligning them straight in line doesn't seem to be right.There is a complex method that only a Saiger video can fully explain.
Ok. Good to hear! I'll line them up straighter then a grizzley's dick and call it good!Personally, I don't worry much about it.
That is the issue. I will give that a shot but I was worried about streaking. I'll just have to check as I go.do you get much overspray dribbles at the wand ends?
Generally only noticed on loop pile and CGD
if so, you might try a slight angle on outside jets
Yeah sorry should have been more specific on the thread. Good to know I'm not the only one to experiencing this.Oh, you didn't say that was the issue. You're screwed on most wands. Angling the outside jets helps some.
The only wand I've ever owned that could be adjusted effectively enough to solve overspray issues is the DevPro, but I have to angle the outside jets even on it!
I like the metal glides, and never have Richard's problems with them.The kind that scratches wood, ceramic and marble transitions and floors, HVAC vents, fireplace threshold.
Foolish idea!![]()
You must be very careful. However I'd rather pay for a glide than to refinish a surface.I like the metal glides, and never have Richard's problems with them.
I don't employ chimps, or refer to my people as such.You haven't, but would you let a chimp loose on it?
