Almost time for the JubiLEE
Delivery of the first 100 units will be in late April.
Choices of:
-Hide-A-Hose length, 10', 15' 20' or custom.
-Slot or Hole Glides.
-Removable circulating system.
-01 or 02 flow.
-And! where to purchase, Pemberton's or GreenGlides..
We'll start taking deposits soon as this first batch will go QUICK!
Choices of:
-01 or 02 flow.
Thanks for sharing this Mike
I'm thinking that the opening order is going to be sold out before arrival.
We'll coordinate our stores and get this started right away.
The purchaser for three less residue franchises has already expressed great interest...
FredBoyle
Fred Boyle
Role
Cleaning Professional
Years of Experience
38
Care to share the cost and which glide you think is superior
My initial thought would be the slots
Would the hole glides leave more lines that need to be groomed out?
The holes will be recessed so no lines and better drying, but will require more thorough pre vacuuming
Under $600 is our goal..
The GreenGlides JubiLee Upholstery Tool
The JubiLee is the result of years of field testing, designed to fill the gap left by the industry’s lost classics. Built for passionate cleaners who want total control—not a "one-size-fits-all" answer—it moves away from the restrictive approach of traditional low-moisture tools.
Key Selling Points
  • Heirloom Titanium Build: Constructed from high-grade titanium, making it 25% lighter than standard tools. It is virtually immune to corrosive chemicals and high-heat warping.
  • The "Misting" Philosophy: Why over-wet what isn't dirty? The JubiLee allows you to "mist" the 50% +/- of a typical sofa that rarely sees soil (backs and sides), drastically reducing water usage and dry times.
  • Optimized Heat Retention: Equipped with a 9502 jet as standard. This specific flow rate is enough to "trigger" your truckmount’s heat exchanger or fuel-fired units into carpet-cleaning mode for consistent heat.
  • Industry-First Overspray Chamber: Featuring four evacuation ports inside the spray chamber to capture overspray or excess solution instead of the water ending up on the floor or your pants—a huge time saver.
  • Precision Pressure Control: Unlike other tools that "spit" if pushed, the JubiLee’s encased spray chamber allows you to run from a mist-like 50 PSI up to a high-flush 600 PSI (200 PSI recommended for most situations). The Jubilee does not leave lines or distort certain fabrics—another huge time saver!
  • Superior Ergonomics: Features a short-stroke head, a 1.25" high-flex hose, and a swivel placed right at the wrist cuff to eliminate the unnatural bend and fatigue common in longer style tools.
  • "Knuckle-Safe" Design: The 1,200 PSI valve and trigger are positioned to keep your hands clear of rough upholstery and the trigger lever away from the fabric.
Standard Inclusions: Comes with a 1.5" x 1.5" Hose connector with vacuum release, adjustable ball valve w/ micro knob to reduce PSI.
Includes shipping to the Lower 48! (Call or write for a quote elsewhere).
Glide Options & Customization
While the 9502 jet is the perfect "all-arounder," you can still customize your physical contact with the fabric with optional 9501 or 9503 Veejets:
  • Fine Fabric (Hole Glide): Maximum dry times for high-end fibers. (Requires thorough pre-vacuuming).
  • High-Soil (Slot Glide): Maximum debris recovery and flushing for greasy, heavily soiled synthetics.
Remote Heat & Water Management
For older or "odd duck" truckmounts that require high water movement to stay hot, we offer a standalone Hot Water Circulating System:
  • Heated-at-the-Tool: The system is located at the hose end, not in your hand, keeping the solution hot without adding weight.
  • Water Disposal Options: Send unused water to the waste tank, a sink, or outdoors.
  • Sustainability Setup: Run an internal 1/8" line back to your fresh tank to save water and chemistry. For the tidiest setup, this return line can run inside your vacuum hose.
Versatile Hose Lengths
Keep your connective cuffs and quick releases outside of high-end interiors to prevent scratches or drips:
  • Standard: 10 ft, 15 ft, or 20 ft.
  • Specialty: 6 ft for portable spotters; 35 ft or 45 ft for aviation and high-end RV detailing.
  • Custom: Call for a quote on any specialized length.
Operator Pro-Tips
  • Detailing Without the Glide: Removing the glide exposes the full 6mm opening, phenomenal for detailing carpeted staircases where a standard wand won't fit. Use extreme care to not scratch delicate wood or metal trim with the exposed framework.
  • Glide Removal & Fitment: Always grab from the front of the head when removing. Because these are hand-welded, you can use a razor to shave a "hair" of Teflon off the end plugs if the fit is too tight—but go slow, as we cannot replace glides due to operator error!
  • Break-In Period: Like a carpet glide, the Teflon will burnish and "wear in" over the first few jobs, becoming smoother and easier to remove/replace with use.
  • Protect Your Investment: Avoid contact with tack strip nails or transition strips that can gouge the glide or the tool head.
    EXTRAS: (click to go to each product page)
Nat
Nat Ismaeil
Role
Years of Experience
4
This is an upholstery tool for the professionals. A must have in your truck for upholstery cleaning. Job well done.
Reactions: Jim Pemberton
Thank you Nat
I've been involved in the development of upholstery cleaning tools at some level in the past 40 years. To my knowledge, none were given the time, attention, and "back to the drawing board" moments that this one has.
By not being constrained by corporate bean counters or engineers with little understanding of the cleaning industry, Mike and I have come up with something unique, and much needed by our industry.
There have been other great inventors to be clear, but they still had to deal with the corporate mentality and limitations that Mike and I haven't had looking over our shoulders.
  • Love
Reactions: Bryce C and Mikey P
Based on some findings today we may just stick with two flow only as it can be ran extremely low pressure and still be effective and it's enough to activate the heat exchanger on a sapphire 370 without the circulating system
