Bawb's crack...
Just got a case. Probably would help to use different color labels for acidic and alkaline versions.
No doubt! I was handed a bottle by the master off the Prochem truck in Saint petersburg!
Was told becareful, I was so careful!
It ended up being the alkaline and all the care for nothing!
I should read label!
Half way through the job a guy who use the stuff says this isn’t the acid it’s the alkaline!
We’re like oh well!
i think it looks great Mikey
HOWEVER
did you forget that spot at the rear
OK ..but don blame ME when little Billy wizzes under the damn moulding.....
OR the turlot overflows under that baseboard
GO BACK...do it right!
and Sam Miller you don wanna see my crack
as i guaranty.... you WILL
be quite traumatized.... once seen.....
you can never unsee it!
Reactions: Willy P and Nomad74
not sure about Meg and FCC....but i can sur the hell tell you about Erik....
i thought he was gonna jump out the damn window
all YOR fault too!
all YOR fault too!
Wow I might need Zipper support stay in the ground!
I love how I see a thread and say I can do that!
Someone mentioned backer rod
In another thread Dealtime!
There I was being a hero, doing my best I wanna be like Mike!
Working 4 plus hours dicking with a shower!
I opened the vertical crack from hell!
Using super grout additive and the trusty
syringe. I realized my mix was too thin!
It kept falling and falling and falling!
So I throw a little more grout and stir!
I finally call my man Mike and he answers right away!
I would totally block me if I were him!
But he’s like ya you need backer rod to fill the crack!
Oh that makes sense well I’m screwed!
Lady walks in that looks so much better!
So my last ditch effort was ad a little more grout to the paste I’ve concocted and push it into the very small drop areas and two small holes that keep reappearing!
I know I’ll hear from her and leave the extra grout!
Then I pray I never see another shower as long as I live!
It’s been a week I hope i didn’t jinx myself!
But the paste may have worked fingers crossed!
Backer rod word of the day!
Reactions: Mike Pailliotet
Walls a real real bitch with SGA, even thick sanded sags and droops...
Duh the crapper was I wasn’t originally going to pull all the crap of the tiny crack I was only going to paste over it!
Like color seal with some filler quality!
But NOOOOOOOO!
I had to try more!
I learned a lot!
DAT
Bill Cheryl
Try welding vertical or ceiling position with 1/4"gap cause someone cut the i beam wrong. Gotta use a backer for that.
is that the same foam rope stuff used for concrete ?
ever the hillbilly I am, think I'd of sliced some blue blocks and chinked the crack
I had those too styrofoam may melt from the glue
