Best method to apply ps to tile&grout?
Josh Almanza
Josh Almanza
What is the best method for putting down my ps to clean tg? Hydroforce? Pump up sprayer??
mop.. unless its an easy unplanned upsell and I'll HF with whatevers mixed up
Reactions: DAT
On my military vinyl jobs.. I use a hydraforce to spray down the same stuff I use on the carpet down the middle of the room then I use a mop to spread it out.
Since I started adding a couple scoops of Sager tsunami to the mix I barely have to scrub them maybe a little pool brush action in front of the kitchen range
@Mark Saiger was l0okin at ur page
and decided to go school teacher on it šŸ˜‰
A mop.
Pay attention.
I agree if there’s stainless and mdf board control is huge.
On track housing with good base boards, and no stainless you can use a hydroforce, lower the psi.
Then crb. Try not to let it puddle on walls is always a good idea.
Acp
Bjorn Marshall
you dont need a bucket, just a trigger sprayer bottle with the top off and pour a few ribbons in the center of the floor... then flat mop it around.
mop from back to front, then clean from front to back so you dont get tile chems/slurry all over your hoses
