Bubble repair advice needed
Lyman
Lyman
The church I go to has gdc in the basement on plywood that has some big bubbles and ripples. I need advice on how to tackle this.
Stevea
If you go through some of the information here, I did post a series of photos showing this.
Let us know if you need more help.
SA
Lyman
Lyman
There are 2 rooms, one is 20 by 30 and the other is 30 by 50 and the problems is in the middle. I was thinking injecting glue and weights.
Stevea
Lyman,
Here is a slide show on how to repair bubbles. I hope this helps, you do not want to do this with a needle, way too much work.
It should be self explanatory Click on the photo to start the slide show
I hope this helps, if not let me know I do have video showing how to do this.
SA
Lyman
Lyman
Thank you steve, could you tell me were to get the glue from and the video would help also.
Stevea
Lyman,
The adhesive is called Bubble Glue and you can look up Shagtools.com, I think that is the correct one that has the adhesive.
I also PM you.
SA
