carpet patch repair?
Bucey
I run across alot in my rentals small areas mostly pets, is this an easy thing to pick up on to repair, would be a great ad on with rentals. any one got a video? or suggestions?
cleanimagemarketing
Steve Andrews is the guy you want to speak with. He really knows repairs inside and out. He also has videos and tools that he sells.
http://www.carpetpatch.com/
You also might want to search the archives here for a ton of great info on carpet repair.
DevilThomas
Yes...carpet repair is lucrative...with the right equipment.... it is easy. The Kool Glide takes most of the hassle out of repairs....
Kool Glide Carpet seamer
Kool Glide tape
3" carpet cookie cutter
Adjustable Circle cutter
Good carpet knife
Small seam roller
Carpet kicker
Carpet awl
Knap shears
needle nose pliers
All this can be carried in a 5 gallon bucket.
Get some carpet scaps and practice....over pad...when repairing be sure to check for any metal...staples, etc and remove them before using Kool Glide. In short order you will be making professional repairs.
John Olson
Cleaning Professional
John Olson
Buy $20 in raffle tickets and I'll send you barrys Kool glide DVD no charge normlly I give it out when you buy a Kool glide. We also have his DVD series I'm going to put on sale for those that buy raffle tickets. He has 3 series a 1 DVD 5 DVD and 7 DVD set.
Nate The Great
In my experience, the circle cutter aka cookie cutter only works good from the back of the carpet. It'll cut face yarns from the top. I have not used the koolglide, but I bet it really takes "hard" out of hardwork. I learned the old fasion way with a glue gun, seaming iron, awl, duckbill scissors, carpet knife.
Steve Andrews has great videos shwoing you step by step how repairs are done. Barry's are also good training, I just prefer Steve's.
juniorc82
I did the carpet repair and reinstallation and I learned alot. I like doing carpet repair work because its just more money on the biill. I also like repairs because not all cleaners can repair and that makes you a specialist
