Jan 4, 2009 #1 E easy1dave Member Joined Nov 2, 2006 Messages 54 My pump started leaking on the bottom where the blue housing goes against the brass.still was abble to finnish job but pressure kept dropping.Is this a easy fix?Thinks in advance.David
Jan 4, 2009 #2 Doug Cox Supportive Member Joined Dec 17, 2006 Messages 4,908 Location Delavan, WI Name Doug Cox Sounds like you need to rebuild it. Cat pumps are pretty easy to do.
Jan 4, 2009 #3 Jim Martin Supportive Member Joined Oct 7, 2006 Messages 10,878 Location Arizona Name Jim Martin you need a rebuild kit for your type of pump... just make sure that you are really careful and pay attention to how each part comes off because the seal are directional...
