commercial cleaning question.
tmiklethun
I had a chain of about 10 dental offices that I was cleaning for over a year.
Last year they pulled all the carpet and switched to an epoxy coated concrete throughout.
They just called me and want me to price a maintenance cleaning to remove the soil film.
Here is my question would you used a prespray and how water rinse or would you use a light prespray and bonnet extraction to remove soil?
Thanks
Small town janitorial
Cleaning Professional
Matt Ross
I would use a mini automatic scrubber. Like a 14 or 15 inch one. Neutral floor cleaner and a red pad. I have several dental office that I do floors for.
Good advice above from Matt and I'd do that as well because I have em. But if you don't, you could do the same with an RE and a red pad. No hot water, but regular and neutral cleaner. Bonnet also isn't what you want. 175 with a tank, and wet vac would work as well. Good luck!!
Goomer
Frank Mendo
I don't know, but I would also be thinking a rotary first.
They cant be that big sq ft wise.
How aggressive can you get with your pads if you needed a little more agitation than most straight absorbent pads offer?
Can you at least grind a white pad under a 90+lb rotary without altering the finish of those epoxy coatings?
Goomer
Frank Mendo
So a frequent dose of red pads wont eventually fook up the finish?
Old Coastie
Stephen
Matt, what precautions do you take to prevent blistering of the finish?
I would just use a tile wand like marty suggests. Can't be THAT dirty
Reactions: hogjowl
DAT
Bill Cheryl
Red buffer pad or white polish pad with neutral clean. That what i have used long time ago. Cant really go wrong with that unless you didnt vac it well..
DAT
Bill Cheryl
Deftly rinse with tile wand..not bad idea too
