CRASHES NEW GENIE
Cleaning Professional
we finished the install yesterday....
next time i charge DOUBLE when the customer heps.......
Crash (against my better judgement) took it out today....
witout a shakedown run....
can't talk to that boy!!!
FIRST SPRAY
a happy customer...
Sweet!
Great job Bob, that going to be nice machine for him to build his business around. 8)
sweendogg
David Sweeney
Aaaaa Man he's chaning your entire business plan.. so much for the new church van's anymore!!
Hoody
Steven Hoodlebrink
Bowling Green, Ohio
Role
Years of Experience
21
Wait till I come for my visit.... :mrgreen:
Tell him to lose those Island Boy shorts he's got on there.
i jus callt Crash to see how everthing is going....
seven jobs down so far PLUS a 1900 sq job at 6:30 pm for the Pontiac school district..
NO shakedown .....
WHAAAA HOOOOO for the Steam Genies.......
Nate The Great
Hey Bob, it may be too early to tell, but what's the difference in gas used between your rejetted old church vans and the newer model Chevy?
no clue.....
bob vawter said:
[quote="Nate The Great":2rdim2lc]Hey Bob, it may be too early to tell, but what's the difference in gas used between your rejetted old church vans and the newer model Chevy?
no clue.....[/quote:2rdim2lc]
I saw CRASH this am...i walked up on the truck while it was running...
sWeeeeeeeeeeeeeeeT machine!
he sez that while running the unit he uses LESS gas than the churchvan...
however driving down the road he uses MORE......
Hoody
Steven Hoodlebrink
Bowling Green, Ohio
Role
Years of Experience
21
He must have a lead foot.
Mr. 007
bob vawter said:
[quote="bob vawter":2c9d2vyq][quote="Nate The Great":2c9d2vyq]Hey Bob, it may be too early to tell, but what's the difference in gas used between your rejetted old church vans and the newer model Chevy?
no clue.....[/quote:2c9d2vyq]
????[/quote:2c9d2vyq]
Reverse that then put a WooT Woot behind it because it Cleans unbelievably! I save more gas getting to and from then the extra I burn running the Genie. I did one of our oldest accounts today and the carpet was at least as old as the account (15 yrs plus) I have Cleaned this home previously and the difference between the Church van and The Chevy :shock: of course "Betsy" (the old Church Van) is 20yrs old. Reliability as well! Richard is Right, Great machine to build my "Empire" around!
Happy Happy Customer! For all Bawbs faults he can get the Job Done Right! Thanks Again
Mr. 007
bob vawter said:
faults????
Bad actuator for the high RPM's. Used part but it will be replaced.
Good News is I can use a Broom stick with a point shaven in one end of the stick so it will stick in the seat to make dollar dollar bills ya'll! Monday that will be taken Care of though.
other than that........ My weld broke on the bolt for the tank easy fix though.
What kinna Hg an' temps ya gettin' CRASH....???
Mr. 007
14-16hg and 200 with cold water & 240-260 with access to hot water.
Mr. 007 said:
he he he you guys are making me blush :oops:
WAY past the blush stage....
HOW BIG WAS IT AL...??? :shock:
i think yor blower is running ABOUT 1800 RPMs?
sam miller said:
does steam genie do a slide in anymore???
lik i tol Larry the other day
slide-ins ain't REALLY truck mounts..
they're kinna Truck-Sits....
they jus SIT in the truck......or trailer..
Steam Genie Direct Drives are the real deal!
bob vawter said:
[quote="sam miller":1sz0yo3j]does steam genie do a slide in anymore???
Steam Genie Direct Drives are the real deal![/quote:1sz0yo3j]
and they don't make ANY STeam Genies anymore
does Crash have a propane heater or blower heat HX'er?
if not...... how can he get 250-260 temps out of liquid transfer HX'ers ????
you sell him bum temp gauge ?
or is his van engine OVERHEATING????
meAt said:
bob vawter said:
[quote="sam miller":r9187tfl]does steam genie do a slide in anymore???
..L.T.A.[/quote:r9187tfl]
exaggerateR....
i tol you 240 degrees hooked up to hot tap water
200 hooked to a cold faucet......
FYI...there ARE different HX's one can use on the Steam Genie....
CRASH has a White Magic HX..
my new SS Steam Genie has a BUTLER HX!!!
EDIT:
i jus looked back at CRASHES post...
and it DID say 240 - 260 degrees
HOLY JUMPIN JEEBUS......that's HOT!
CRASH...can you confirm that temp???
HEY CRASH
see the WM HX....
bob vawter said:
exaggerateR....
ummm.....
I colored it in rEd fer ya
forgive my ignorance of thermal dynamic physics...but how does a HX'er make hotter water than the engine anti-freeze in the HX'ers?
even with "hot" water going in
meAt said:
bob vawter said:
exaggerateR....
ummm.....
[quote="Mr. 007":30m4p9a9]14-16hg and 200 with cold water & 240-260 with access to hot water.
..L.T.A.[/quote:30m4p9a9]
it's a festivus miracle?
i'll check it out wit my own eyeballs when i see him tomorrow!
Mr. 007
It was a long run commercial job, truck was running with a stick before I had my solenoid all set up,(first day) and probably runnin way to many RPMs. anyway truck was running about 220 on the gage & had hot water access. i know that was the shake down run but it has not been that hot sense :lol:
On a good note I finally had a minute to write this post because it's been working non-stop sense the install! Life Is Good!
good to hear you're busy, Crash.
also good to hear the Genie is running well
and lastly...good to hear you won't be needing to replace head gaskets and mill warped heads.
cause if/when you start getting heat above 230 with liquid HX'ers, your van engine is OVER HEATING... :shock:
If I lived near Bob, I might consider getting one of his Genies. Or, I might consider moving.
If I bought one from him, the old fart would probably die the next day and leave me hanging for support.
Martin.....
TWO WORDS HERE:
Proprietary......
Standardized......
always get the machine wit STANDARDIZED components......and don't forget ta turn it on....
(not in the DAnny sorta way)
