- Oct 6, 2006
I can't imagine a better wand than the D12.
What happened to nate, did a shark eat him.
Well your going from 8 flow to 6, and losing 2 inches.Can I get the same or better dry times with the d12 as my dang14. I like a slot glide. I am not starting trouble. What matters to me is my customers, dry times are huge.
I mainly run 14 inch and had the same concerns.Well your going from 8 flow to 6, and losing 2 inches.
But it has serious bite with dry strokes it wonāt be longer.
Itās easier to maneuver in homes.
Still on really large areas youāll want the bigger wand for production.
Itās only as fast because your old and move faster with a lighter wand hahahahahahI mainly run 14 inch and had the same concerns.
However after direct comparison on the same route it's our consensus that production is just as fast with the Dev 12x1.5 .
Quality of work was better (appearance & drying), and Jon said the ergonomics were better.
My speed doesn't really matter. Jon is 34, Justin is 38 (and already hurting).Itās only as fast because your old and move faster with a lighter wand hahahahahah
The death of Devastator has begun.No dealers
No demos
He's setting up with a different manufacturer that will reduce cost and improve availability.
Are you interested in a 2" or 1.5"?
I doubt it lol, I can't keep them in stock now. I am just waiting on sample, if it passes quality check, and I believe it will be fine,..... I should never have supply issues ever again.The death of Devastator has begun.
Well.... Seems like an easy choice.focus solely on my tool
Cleaning is virtually recession proof, selling tools isn't.We are taking this time to really evaluate what I want to do....keep cleaning and making wands, or just drop my c c business, and focus solely on my tools.
Tom is setting up with a new manufacturer now.
He may have some in stock
I have a few 1.5s in stock.....
Well as of 10:45 am on 8 16 19
Well I have my Dev and wow the suction is Great. Used it a for times and due to my old age I can only use it on the first job on some carpets due to shoulder pain. Now I can go back with other wand with glide no problem. but more strokes but less suction. I will try to use it as much as possible. Great wand Tom just wish I were a few years younger. It makes my simple Cobb 2045 a monster. jz.
Should have got the 1.5 you old fart
Yes that's what I have Tom said if your over 50 don't get the two inch you have to bench press 400lbs the same as the vacuum in the two inch. the other is for old guys& ladies that clean carpets. jzShould have got the 1.5 you old fart
