Embedded shushi
I'm sure a enzyme high ph prespray would have done better.
Scrub it in with the GLS and extract.
I had PP, Pre Kleen and 02 in my HF.
A GLS would have dont nothing. That crud was hard as a rock.
Jim Nelson said:
...If you take the glide off you wont need fans to dry the carpet.
Removing a teflon glide to get more agitation on a grease slick has merit....but claiming it will dry better without the glide is crazy talk.
Some jobs just need a garden hoe. lol
sweendogg
David Sweeney
Garden hose... or a pressure washer? Wonder what would have happened if he had tried his spinner at 1200 Psi??? Whats the worse that could have happened? Have his monkey sit there with a glided wand ready incase it wond it extract up over carpet? Seems like the RX or RV would have saved him some wand passes.
Jesse
I think a stripping brush would have done well, the pad gets too gunked up to work. It's to bad 3m doesn't make a #7300 red or green pad.
